Cooling Fan and prob AC
Low refrigerant will keep the compressor from staying engaged. It will cycle on/off because the pressure switch will detect a low pressure charge.
I’m not sure how the fan is programmed. I would assume when the compressor cycles “OFF” that the fan turns off.
