Cooling Fan and prob AC
Old Jun 21, 2023 | 05:05 PM
2008LShhrHou's Avatar
The ac light does not go off....turn black
Old Jun 21, 2023 | 05:22 PM
Low pressure guage 50, high guage 155
Old Jun 21, 2023 | 05:24 PM
Freon is low.
Old Jun 21, 2023 | 05:29 PM
Omg I hope you are right. Can you tell me what the correct readings should be?
Old Jun 21, 2023 | 05:32 PM
I found this...."If the humidity is above 50%, you should see between 30-45 psi on the Low Side Service Port, and 192-251 psi on the High Side Service Port."????
Old Jun 21, 2023 | 05:51 PM
  #26
Does low refrigerant keep the fan from turning on?
Old Jun 21, 2023 | 06:35 PM
  #27
Low refrigerant will keep the compressor from staying engaged. It will cycle on/off because the pressure switch will detect a low pressure charge.
I’m not sure how the fan is programmed. I would assume when the compressor cycles “OFF” that the fan turns off.
Old Jun 21, 2023 | 09:55 PM
  #28
PulpFriction's Avatar
How do you know the radiator fan is running when you're driving the car? I would want to know how it behaves parked with the hood up.
Old Jun 22, 2023 | 06:28 PM
  #29
In Houston this week it would get warm enough idling for 15 minutes or less. The weather man says ambient is around 108F .
Old Jun 27, 2023 | 05:22 PM
  #30
Wonder why the OP hasn’t been back to his thread ?
(Well. He’s been back several times, just no updates)
Me. I was curious if he got it fixed.
