Cranks, but will not start. Whole slew of repairs
Old Apr 21, 2022 | 09:18 PM
Frisco84's Avatar
Originally Posted by donbrew
Why do people replace sensors when the code plainly refers to the CIRCUIT?????? That means a wire, connector or fuse and a very long shot is a wire inside the epoxy potted sensor is broken.
Why not just replace "the computer"? It would make more sense (just kidding).
How did it test bad?
I should've had some voltage on cranking but I was getting zero. Additionally Resistance was zero. As far as the crankcase sensor, I had voltage, but resistance was lower than spec (20 ohm)
Old Apr 21, 2022 | 09:45 PM
So what numbers did you get after replacing the sensors?
Old Apr 21, 2022 | 10:13 PM
Frisco84's Avatar
On crank fluctuations from 1.4 to 3 volts, 5 with key on. 200 ohms give or take 1 to 2.
Old Apr 22, 2022 | 12:40 PM
greg8453's Avatar
Do you have a meter where you can measure the output of the sensor for frequency and amplitude? If so, Check to see if you are getting the same amplitude at the computer that you get from the sensor itself. If so, The wiring is good and If pin tension is good on the connectors than that circuit is fine.
Old Apr 22, 2022 | 05:36 PM
Frisco84's Avatar
I ran a check again, only code I'm getting is P0016.
Old Apr 22, 2022 | 06:01 PM
Shoot, that's the timing chain. Do not crank the engine anymore.
Old Apr 22, 2022 | 06:04 PM
Yes, change the timing chain and balance shaft chain. It is off by 1 or more teeth. You risk bent valves if you start it.
Old Apr 22, 2022 | 06:24 PM
Frisco84's Avatar
Excellent, I'll adjust timing tomorrow and report back here how it goes.
Old Apr 22, 2022 | 07:06 PM
Adjust? You have to take it all apart to set the timing. At 150,000 miles, you need to put in a new timing set.
Old Apr 22, 2022 | 08:39 PM
greg8453's Avatar
You should take it to someone that can fix it. You have no idea what you are in for.
