crazy car
Old Sep 1, 2014 | 11:51 AM
LawDog88's Avatar
Originally Posted by donbrew
Check the large red wire connection to the fuse box.
Add to that, make sure that it's seated correctly.
Old Sep 1, 2014 | 03:39 PM
carolsargent's Avatar
We are off to get a new battery. I'll let you know how the car is working after that
Husband checked fuse 28 and it tested ok.
Old Sep 1, 2014 | 07:18 PM
Hooray........New battery............car is ok............Thank you all for your guidance and help. Bless you
Old Sep 1, 2014 | 07:23 PM
Welcome to the site ,enjoy that HHR!
Old Sep 3, 2014 | 10:32 AM
Oh no....new battery....car ran great for l day and then did exactly what it did to start this mess.....any thoughts...thank you
Old Sep 3, 2014 | 10:38 AM
fuse box under the hood, as mentioned earlier in this thread
Old Sep 3, 2014 | 10:39 AM
Get the charging system checked. Sounds as if it's not charging the battery back up.
Old Sep 3, 2014 | 10:43 AM
... and most Auto parts stores will test the charging system for free (as they do for batteries).
Old Sep 4, 2014 | 07:29 AM
well, no charging problems.....our mechanic is looking for a drain on the battery.
Thought....We had the ignition replaced by dealer here according to recall. Since then we had key stuck in ignition switch because of a part failure (don't remember name but I remember part cost 500. Gas mileage down to ll miles/gallon. Now this electrical drain. Up to this point, we have had no problems with this car in 5 years and 97,000 miles. Anyone had problems with this recall? Thank you for any help.
Old Sep 4, 2014 | 09:42 AM
Have your guy check the throttle position sensor. When they go bad they can cause a drain, usually it throws a code......but.
Ijazzu
Maintenance and Upkeep
7
Jan 2, 2015 02:00 PM
Jeff®
May 10, 2010 01:52 PM
tireman1554
Jul 16, 2009 09:17 PM
Don Juan
Mar 8, 2009 08:29 PM
