Creaking from brakes
Old Nov 25, 2012 | 01:25 PM
llamuh's Avatar
Originally Posted by 2007HHRLT
Check you Caliper pins and bracket. Make sure they move in and out freely. I had one stick and it made a creaking noise.
I could see this being a (my) problem. I checked at some parts stores and it looks like the pins and such are pretty cheap to replace which makes your solution even better. If the pins were to get stuck and I were to replace them, what type of lube would I use for them? Some sort of lithium grease or something?
Old Nov 25, 2012 | 01:40 PM
2007HHRLT's Avatar
I bought a Pin kit and they came with grease.. I never checked to see what type it was.
Old Nov 25, 2012 | 03:49 PM
llamuh's Avatar
Oh OK. Well, thanks for the suggestions guys. I'll try the pin kit and then the brake pads. Or maybe just go ahead and do both at the same time since I'd be working with the calipers regardless.
Old Nov 25, 2012 | 04:39 PM
hyperv6's Avatar
I think the pins are not it and the pads are the issue but it will not hurt to change them first just to see if it is the issue.
k5hart
May 29, 2019 09:09 AM
drummerboy0088
12
Mar 17, 2015 12:19 PM
Marcruger
"How To" Tutorial Library
0
Dec 29, 2009 06:32 PM
MikeX
Mar 21, 2009 07:49 PM
jbbadboy
Feb 8, 2009 08:14 AM
