Cruise Control Will NOT Engage
Old Jun 3, 2019 | 06:50 AM
  #31
hperrenot's Avatar
Originally Posted by whopper
What temperature does it run now that you have replaced the thermostat?
about 170-185°. Thermostat has been replaced and CC still doesn’t work
Old Jun 3, 2019 | 07:36 AM
  #32
170 after warmup ? If so, anything below 180 is too low.
Either a bad thermostat or you didn't use a AC Delco brand. -----Reread post #24------
Could have trash remnants from the old thermostat sticking the new one open.
Check Engine Light On ? (P0128 code maybe)
Even if not on, pull the codes again. As stated, certain codes will render the CC inoperative.
Old Jun 3, 2019 | 08:06 AM
  #33
And another thing, the clock spring in the steering column, you stated the CC has never worked.
https://www.chevyhhr.net/forums/prob...control-48767/
You replaced the thermostat, please confirm which thermostat was installed?
Old Jun 3, 2019 | 11:12 AM
  #34
hperrenot's Avatar
Used a Murray brand thermostat because the specs were identical to AC Delco. The horn works so I fired the clockspring was intact because in my truck the horn working means clockspring is good.
Old Jun 3, 2019 | 11:23 AM
  #35
Did you not read the previous posts about ensuring you use the DELCO thermostat? There is a reason for it - and I won't waste my time explaining it again - as it has been explained numerous times.
Firemangeorge is correct in his previous post - it is still running too cold.
Re: clockspring - fyi it is entirely possible that the clockspring can affect the CC without affecting the horn. Replacing the clockspring can be a very dangerous task due to the need for replacing the airbag. So it is probably best to leave that to a professional.
Old Jun 3, 2019 | 11:33 AM
  #36
hperrenot's Avatar
I will get an AC Delco thermostat and try again.
Old Jun 3, 2019 | 11:59 AM
  #37
The Murray one ..
Old Jun 3, 2019 | 01:18 PM
  #38
Cat Man HHR's Avatar
The Murray one ..
He said:
"I will get an AC Delco thermostat and try again."
Old Jun 3, 2019 | 01:45 PM
  #39
Ok, I thought he did already.
in post #24, Whopper states the AC Delco 131-158 thermostat.
then in post #24 the quote is.... new thermostat.
he doesn’t say , he cheaped out and got a Murray.
Learn the hard way, like many of us have.
We’re here to help you, save you money and ensure you are informed of what works on our trucklets.
What next , you used the green coolant?
Old Jun 3, 2019 | 03:29 PM
  #40
hperrenot's Avatar
I didn’t cheap out. I got what the parts store has in stock that day. it was equality n specs so I figured it wouldn’t matter. a $15 thermostat isn’t going to break my checking account
