cyl 3 misfire
Old Dec 22, 2013 | 05:43 PM
Never got an answer to: Did this come about after the plugs and filter, or was it there already?
The P0303 only sets a CEL after it occurs a few times, so you may have had a pending code.
Old Jan 17, 2014 | 08:08 AM
JLD333's Avatar
Sorry the P0303 and 1174 codes were prior to the new plugs. Swapped coil packs still receiving same error codes. The car runs like normal. If the light was not on I would think everything was fine. Should I still do injectors or would it possibly be something worse such as burnt valve. Finances are tight right now. I also need to replace brakes and rotors and windshield to pass state inspection.
Old Jan 18, 2014 | 07:54 PM
Have you looked at the flex pipe? Have you done any troubleshooting or, just parts shooting?
Try switching the injectors around.
Could be a vacuum leak (including the EVAP solenoid and/or valve), could be a busted flex pipe, could be a bad #1 HO2 sensor, could be a bad #2 HO2 sensor, could be a bad MAF sensor, could be a bad MAP sensor.
Probably a burnt valve or bad head gasket. Do compression and leak down tests.
jdjaa1959
Maintenance and Upkeep
14
Jan 7, 2015 08:09 PM
ULOS2A6
Mar 24, 2014 03:52 PM
Cheko0602
Dec 7, 2013 11:45 PM
dzmija
Oct 27, 2013 04:34 PM
tleffew66
Jun 11, 2013 11:16 PM
