Dash lights flickering ,no crank no start
Old Jan 17, 2024 | 01:25 PM
Rockinron's Avatar
Originally Posted by Rockinron
will do going to attempt it today after work , not snowing but still a bit cold,
im going to check the bolts in the fuse box but im a little worried I might crack it.
when I put the grease on do I put it on both sides??
Old Jan 17, 2024 | 02:49 PM
No one side will do
Old Jan 17, 2024 | 04:45 PM
Rockinron's Avatar
Originally Posted by Oldblue
No one side will do
well I was able to tighten the 4bolts on the fuse box they were loose tighten them up a lot still no start pulled the TCM connection of cleaned with nylon brush put a bit of Dielectric grease on the holes side plugged back up n still No start? Should I put more grease on the Connection?
Old Jan 17, 2024 | 04:52 PM
Rockinron's Avatar
thinking I should do all the connections?
Old Jan 17, 2024 | 04:55 PM
You’ve mentioned the TCM numerous times. Is there something you’re not telling us ? Why only mention the TCM ? Could just as easily be a ECM or BCM problem.
Old Jan 17, 2024 | 04:59 PM
  #26
Rockinron's Avatar
just from what I saw on YouTube, should I put grease on them other two connections? I put a small amount on the TCM or should I smear the grease on to make a better connection?
  #27
Rockinron's Avatar
that’s the two other connections below?
Old Jan 17, 2024 | 05:13 PM
  #28
Rockinron's Avatar
The EPS looks blown 60amp
Old Jan 17, 2024 | 05:22 PM
  #29
So when you Jumpstarted it, where did you hook up the jumper cables? If one clamp was on the post on the side of the fuse block with the 2 red wires, it blew the EPS fuse and possibly fried the fuse block. And there should only be 1 red wire on that post.
Old Jan 17, 2024 | 05:34 PM
  #30
Rockinron's Avatar
yes I did try to jump start with the two connections on the picture, should I replace the 60 amp fuse?
the two red wires were in that position when I cleaned the connection
