Dash lights flickering ,no crank no start
Old Jan 17, 2024 | 05:37 PM
  #31
Rockinron's Avatar
Originally Posted by Rockinron
the two red wires were in that position when I cleaned the connection
could this be why dash lights are on head lights are on and bright but when I turn the key no crank no start?
Old Jan 17, 2024 | 05:47 PM
  #32
Rockinron's Avatar
I have one 60 amp fuse
Old Jan 17, 2024 | 05:52 PM
  #33
You do know that those 2 big lug connections are both positive 12 volts ? If you hooked up the jumper cables (+ and -) to those positive posts, then you may have fried some electronics.
When jumpstarting, the negative jumper cable should be grounded on the strut upper bolts.
Old Jan 17, 2024 | 06:05 PM
  #34
Rockinron's Avatar
yes I realize this now but nothing has changed, I just checked all the fuses 10/15/20 there good malti meter beeped,checked all grey relays with a 9 volt battery and they all clicked
Old Jan 17, 2024 | 06:06 PM
  #35
Rockinron's Avatar
how do I check the 60 amp fuse with the multi meter?
Old Jan 17, 2024 | 06:11 PM
  #36
Rockinron's Avatar
will do going to attempt it today after work , not snowing but still a bit cold,
im going to check the bolts in the fuse box but im a little worried I might crack it.
Old Jan 17, 2024 | 06:12 PM
  #37
Rockinron's Avatar
Old Jan 17, 2024 | 06:32 PM
  #38
Rockinron's Avatar
after leaving the key in the ignition in this picture for a few minutes all lights went off and could not get the key back out wiggling the gear shift the key turned back came out, put it back in turned key and all dash lights started blinking then they turned off and the lock picture started blinking, tried the key again they all came on turned key off and the dash lock blinking again locked the car closed the door and the security lock blinked on and off like normal???
Old Jan 17, 2024 | 07:07 PM
  #39
Rockinron's Avatar
seams like I’m going in circles
Old Jan 17, 2024 | 08:03 PM
  #40
Rockinron's Avatar
any body have any ideas
