Dash lights flickering ,no crank no start
You do know that those 2 big lug connections are both positive 12 volts ? If you hooked up the jumper cables (+ and -) to those positive posts, then you may have fried some electronics.
When jumpstarting, the negative jumper cable should be grounded on the strut upper bolts.
after leaving the key in the ignition in this picture for a few minutes all lights went off and could not get the key back out wiggling the gear shift the key turned back came out, put it back in turned key and all dash lights started blinking then they turned off and the lock picture started blinking, tried the key again they all came on turned key off and the dash lock blinking again locked the car closed the door and the security lock blinked on and off like normal???
