Dashboard noise
Old 03-23-2019, 02:59 PM
athenas dad's Avatar
Dashboard noise
Hi all,
I have this strange noise coming from the drivers side dash area. It sounds like air leaking and increases with the rpms. I had the intermediate shaft replaced and thought it was from the rubber boot coming loose, but its not. Cold,Hot temps ok, indoor,outdoor exchange working properly. Brakes ok, no fluid anywhere, level full. I would like to believe its not radio related ,but not sure.
What do you guys think ? Im going crazy trying to find the source !
athenas dad is offline
Old 03-23-2019, 03:02 PM
When do you hear it? Parked, moving, always, foot on brake, etc.
donbrew is offline
Old 03-23-2019, 03:10 PM
its all the time after start up. all gears. No shifting problems or shifting hard.
Old 03-23-2019, 03:24 PM
I’d double check the boot, it isn’t easy to put back into place. It might look seated but it probably isn’t.
check the wire harness boots to the doors, they can pop out of place.
Oldblue is offline
Old 03-23-2019, 03:46 PM
flex pipe.
If it has nothing to do with moving or moving the steering wheel why put any energy into the intermediate shaft?
Why can't you tell if it is a speaker? You obviously are not deaf, just put your ear near the tweeter on the widshield support and the speaker in the door.
donbrew is offline
Old 03-23-2019, 05:05 PM
I'm with donbrew, if you hear it while parked, engine running, it's not wind noise. Flex pipe is the likely culprit.
RJ_RS_SS_350 is offline
Old 03-23-2019, 05:17 PM
Ok, but if the boot isn’t in correctly, you get not only noise but fumes, so are you smelling any , fumes?
Oldblue is offline
Old 03-24-2019, 01:15 PM
So I just went out and looked at the intermediate shaft and found out the boot is ripped. Its a pain to even put your body in that position and look up in the area lol.
I believe when i had it replaced the mechanic must have used lubricant to get the boot sealed as I had black residue on my finger probably from the rubber being melted from the lubricant.
Im glad i found the culprit but i dont think ill be able to replace just the boot. Any ideas how i can seal it ? Thanks
Old 03-24-2019, 02:42 PM
Goop or Flexseal.
I had a feeling it ‘‘twas the boot.
Oldblue is offline
Old 03-24-2019, 03:04 PM
What is making the noise?
Take it back to whoever did it! They broke it not you.
Grease in that are could come from a split CV boot.
Rubber does not melt from lubricant.
donbrew is offline
Quick Reply: Dashboard noise
