daytime running lights stuck on
Old Jul 19, 2010 | 04:53 PM
ewmiles's Avatar
howdy folks. new to the site. driving an '06 hhr. driver headlight stopped working one day. replaced it. passenger front turn signal stopped working. replaced it. next day, found that park lights wouldnt go off after turning car off. time was midday with no clouds. lights stayed on about 30 mins and went off. same thing happened at night as well. park lights began staying on longer after engine shutoff. eventually got to point that park lights would not go off at all. ran battery dead. jumped car off. park lights still wouldnt go off. tried control stick as well. works low beams, hi beams, but will not shut off park lights. only way to turn them off is to pull relay or fuse. now my autolights do not work at all. think i remember light sensor on dash being slightly transparent, but now completely black. any help would be greatly appreciated.
Old Jul 30, 2010 | 01:45 PM
ChevyMgr's Avatar
When you turn the car off and the lights are still on, does the chime go off when you open your door?
What brand and part number bulb did you put into the passenger park lamp?
Old Jul 30, 2010 | 05:35 PM
ewmiles's Avatar
i turn the key to shut the car off. take key out of the ignition. open door and chime dings to let me know the lights are still on. walk around car, and all park lights are on. pull park light relay, and park lights go off, but chime keeps dinging until door is closed. in addition, entire instrument cluster stays lit for twenty minutes. park lamp is eiko brand, 3157 replaces 3157sa. headlamp is sylvania h13.
Old Jul 31, 2010 | 10:57 AM
ChevyMgr's Avatar
Have you tried turning the light switch manually after you shut the vehicle off?
Old Jul 16, 2011 | 12:12 AM
ewmiles's Avatar
finally got the car to the shop. as it turns out, it ended up being a body control module.
brazodoro
Apr 7, 2014 09:36 PM
helhedded
Dec 1, 2011 08:13 PM
Sasksurfer
Apr 24, 2010 11:12 AM
Marzipan
Feb 24, 2008 11:35 PM
helhedded
Feb 22, 2007 09:43 AM
