Diag Code P0303
Old Jun 18, 2022 | 09:42 PM
greg8453's Avatar
Originally Posted by brostrompaul@gmail.com
I have the same problem, but have not tried a compression test and haven't cleaned the fuel rail. Any other suggestions???
Did you swap injectors and coils? If so, and still number three hole you need to do a running compression test.
Old Jan 31, 2024 | 09:05 AM
HB2's Avatar
HB2
How do you clean the fuel rail?
Old Jan 31, 2024 | 10:08 AM
You let off fuel pressure, by removing the fuel pump fuse and let the engine idle until it stops, then remove tge 2 10mm head bolts that hold the rail in place , remove the fuel injectors and squirt throttle body cleaner in the holes. You don’t have to remove the fuel line, but it helps. You need a tool for that.
Old Feb 2, 2024 | 04:14 AM
HB2's Avatar
HB2
Thanks, Oldblue.
Lee3333
Mar 31, 2017 09:17 PM
RudyInTheSkies
2.2L Performance Tech
10
Sep 22, 2016 05:20 PM
douglas
Jan 21, 2014 03:55 PM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
