Dim Passenger Headlamp
Old Aug 7, 2014 | 07:05 AM
nageeeK's Avatar
1st post.....I bought the 2009 HHR in December 2013. I have replaced both headlamps (probably around Dec/Jan).....driver side was out when I bought it and then the passenger side followed suit a month later.
Just noticed that the passenger side headlamp (low or high) is very dim.....it is not totally out. It is almost like a dim glow on both low and high. The driver side lamp is fine. I am thinking a ground issue. I found a schematic by Lucky but it is too small to be able to read it.....does anybody have a larger 2009 HHR Headlamp schematic that they could post or PM me? Does anybody know where the ground for the passenger headlamp terminates?
Thanks for your help.....the site is very helpful.
dobe77
Old Aug 7, 2014 | 07:45 AM
Welcome to the site.
The wiring schematic shows both headlight grounds to be in the left engine compartment area.
Left side headlight says: left shock tower
Right side headlight says: left engine comp. area
All of the exterior front lights, horn, ps module, ebcm,and horn all show to ground at these 2 points. I would be looking for a heavy gauge ground connection.
Old Aug 7, 2014 | 07:58 AM
This one by the fuse box may be what you're looking for.
Not sure where the other one is.
Name:  ground point.jpg
Old Aug 7, 2014 | 08:39 AM
My bet is that the bulb has become dislodged.
Old Aug 7, 2014 | 09:33 AM
skyline26's Avatar
i have the same issue with my HID's...my driver side is so bright compared to my passenger side
Old Aug 7, 2014 | 12:54 PM
nageeeK's Avatar
Appreciate the comments and suggestions.....I will investigate further after work and respond back with what I find.
skyline26 - when I mentioned "glow"......that is literally what the light is doing. It is not throwing any light forward, but if you look close enough, the filament is glowing. I can understand bulbs having a different brightness, but this is not the case. Not slamming your comment....I appreciate them all. I just wanted to clarify what I was witnessing.
dobe77
Old Aug 7, 2014 | 07:38 PM
nageeeK's Avatar
Problem solved.....donbrew wins the award for diagnosing the problem.
I found the two grounding terminations on the left side of the engine. I first loosened up the two wires that firemangeorge had a picture posted of - left engine compartment. I tested the lights and the left and right headlamps came on (still dim on the passenger side) without those ground wires connected....that told me that the ground wires to the headlamps were somewhere else. Reconnected those wires and found the ground connection on the left engine tower (behind fuse box). I remove two wires from the stud and the lights would not come on. Verified that I had a good connection and tightened them back up. Still had a dim passenger headlamp. I then removed the right splash guard to access the headlamp bulb....removed the connector and reconnected it. Tested lights and behold they both illuminated correctly! I took the connecter apart one more time and sprayed an electrical contact cleaner on it. It is good to go for now....must not have had a good connection.
Thanks for the ideas.....hope someone else can learn from our thread.
dobe77
Old Aug 7, 2014 | 08:01 PM
Glad you got it fixed.
The sad part is, I have to admit a defeat to donbrew.
Old Aug 7, 2014 | 09:43 PM
It's OK George, Don has outhought most of us st one time or another, the man is a troubleshooting machine.
Old Aug 8, 2014 | 07:26 AM
Donbrew does it again!!! Glad to read all is well now!!!
