Dome light and rear hatch
Old Feb 5, 2008 | 12:59 PM
calgaryhhr's Avatar
Here's what was on my work order, this was taken care of at the beginning of December. I should also add that the prior December (2006) my HHR had a problem where the rear hatch actuator gave out and it was replaced. I don't know when my dome light stopped working (if it worked at all) with the rear hatch open but I'm thinking that this previous repair may have had something to do with the light not working?????
My invioce says: "Install SOP lock to correct inter dome light. Cause: B5880 Rod and/or latch, tailgate lock - R&R or replace. Replace trunk lock with actuator."
Old Feb 5, 2008 | 04:10 PM
Snoopy's Avatar
Post
I'll post this TSB for people who may need it.......also for historical reference.
Note that GM specifies to use update software AND to update the Tech2 equipment. Maybe some Dealers have not !!
Old Feb 7, 2008 | 05:24 PM
suburbanjunior's Avatar
Well good news on this problem. I just got the car back from the dealer. The BCM was bad and they had to replace it. They tried to update the BCM according to the TCM mentioned earlier by Snoopy and that did not work. They finally changed it and now the interior lights work as they are supposed to. Thank you for your suggestions, John
Old Feb 21, 2008 | 12:12 PM
454Taylor's Avatar
Wonder how much the BCM is out of warranty.
tomw
Jan 26, 2017 04:26 PM
lgaston1
"How To" Tutorial Library
Oct 29, 2014 11:54 AM
Happy13178
May 14, 2012 11:59 AM
BeanWagon
Jan 5, 2012 04:00 PM
twr4d
May 13, 2009 01:13 PM
