Door jamb pin switch
Old Nov 13, 2014 | 11:10 AM
Grimsby's Avatar
Does anyone know the correct way to remove the pin switch from the door jamb? I know the switch is bad, but I don't want to break anything else trying to remove it.
Thanks
Old Nov 13, 2014 | 06:48 PM
hhr11's Avatar
Not sure if yours is the same but on the 2011 there is a small tab on the side of the switch that you have to use a small blade screwdriver to press. I don't remember what side as it was some time ago I removed mine. Also, when pulling the switch out try to get a hold of the electrical connector so as not to let it fall back in the hole. If it does you will need to remove the kick panel to get at it.
Doctor Who
May 31, 2015 11:27 AM
VinceP
Mods - Interior
May 14, 2011 12:15 AM
bossrod
Mar 4, 2011 12:49 PM
Leon
Aug 12, 2008 05:01 PM
06Daytona
Jan 5, 2008 04:04 PM
