Door Cup and Mirror Switch Mount
Old Aug 12, 2008 | 01:46 PM
Leon's Avatar
Does anyone have the Ebony interior with a black door pull cup? I would assume if the car has the Ebony interior the door cup would also be ebony, but when I try looking them up online, all I find is grey and cashmere. There is a part number on the bottom of the cup but since mine is an '06 it only lists the two colors. I'm looking in the '07 and '08 parts sections, but still can't find anything. I've painted my pieces, but I'm thinking with the constant wear they will get, an ebony replacement would be better. If anyone can get a part number off of one I'd really appreciate it. Here's what I'm doing to the doors:
Old Aug 12, 2008 | 01:51 PM
ChevyMgr's Avatar
Ebony = 15281483 (Passenger)
Ebony = 15281484 (Driver)
These are the door pulls. Is this what you wanted?
Old Aug 12, 2008 | 04:49 PM
Leon's Avatar
These are for the front doors? I figure those are the ones that get all the wear. I found a listing in GMPartsDirect for the back door cups (door pulls) so I only need the front.
It's part # 13 on the diagram
What I found for the back doors were called "Pull Pockets" and available in black but GMPartsDirect doen't list the fronts in the catalog in black. Those part numbers do come back to a "cup" so I immagine that's what I need. The driver's side is longer to mount the mirror switch. Both are 11.73, but in the grey the driver's side is more?
Thanks for the help.
Leon
Old Aug 12, 2008 | 04:57 PM
ChevyMgr's Avatar
I believe they are what you are looking for. They cost around $15 each. That's a weird blow up of a door panel, but if you are talking about the cup that your fingers go into to close the door then those are the part numbers.
Old Aug 12, 2008 | 05:01 PM
Leon's Avatar
yep - that be the part then. thanks.
guppy
"How To" Tutorial Library
Oct 22, 2013 01:42 AM
Dunny
May 12, 2013 10:38 AM
MikeRuth
Mar 12, 2012 02:22 PM
Sparky21440
Mar 10, 2010 08:46 AM
UncleDannie
12
Mar 5, 2009 01:37 PM
