Door lock not working.
Old Sep 26, 2009 | 12:06 PM
06Daytona's Avatar
Question Door lock not working.
My rear passenger side door lock will not function. I can manually pull it up, press the remote and the lock will not move down. I can push it down, press the remote and the lock will not move up. I can hear the relay trying to do something when I press the remote, but it won't move the lock.
I took the door panel off and remove the entire lock mechanism from the door. I could see some hex screws that seemed to hold the entire thing together, so I removed them all to see if I could see anything, but I couldn't pry the top off.
My guess is I will have to replace the entire lock mechanism for that door.
Anyone know where and how much this thing is?
Thanks.
Old Sep 26, 2009 | 04:46 PM
prod's Avatar
Im taking mine in for the exact same issue next week. They tried fiddling with it and bending the rod initially, but that did nothing. They then determined it was binding inside the lock mechanism itself, which means replacing it. The dealer doesnt stock them so it took a week before they got it. Luckily Im still under warranty.
Old Sep 27, 2009 | 12:49 PM
06Daytona's Avatar
Ya, I'm way beyond warranty coverage. This will be a DIY project for me.
Old Sep 27, 2009 | 02:02 PM
RaineMan's Avatar
I'm wondering how long it will be before I have to do the same. My passenger front doorlock is what I can only describe as slow. Sometimes it locks and unlocks when I hit the button... sometimes I have to hit the button twice.
Old Sep 27, 2009 | 06:26 PM
BlackHHR06's Avatar
Smile Door Locks
Hi Guy's, take a look at the TSB section on here. There is a TSB on door locks binding due to the hole in the door panel, it's to small and causes the lock button to jam.
I had this problem until I filed out the holes in the plactic panel. I'll see if I can find the correct TSB for everyone ??
Old Sep 27, 2009 | 06:45 PM
BlackHHR06's Avatar
Smile Tsb
Go to the TSB posts and then page 9, PIC 5190 #82
Hope this helps everyone????
Old Sep 27, 2009 | 09:22 PM
RaineMan's Avatar
Speaking of locks. Is there a way to shorten or cut off the locking posts? They're too damn tall, they get in the way of me and my passengers resting our arms on the door when the windows are down.
Old Sep 27, 2009 | 09:26 PM
RaineMan-
I removed the door lock knobs, measured & trimmed the threaded studs & wound back on my chrome lock knobs.
Now when doors lock, they are almost flush. And I did file out the holes in the door panels slightly, just seemed too snug of a fit...
Old Sep 27, 2009 | 10:26 PM
prod's Avatar
Yeah i told them about the tsb for the door trim but they said that wasnt the problem in my case.
Old Sep 28, 2009 | 06:09 AM
06Daytona's Avatar
Thanks for the info.
I don't think that this is my problem. I completely removed the latch from the door and with the electrical still plugged in, I actuated the lock and it still would not move either way.
dmfost
Mar 15, 2015 04:31 PM
bossrod
Mar 4, 2011 12:49 PM
Chevy SS
Jun 17, 2008 11:51 PM
oneton
Aug 6, 2006 11:43 AM
TX-HHR
22
Aug 2, 2006 07:19 AM
