Door Lock Wiring
Door Lock Wiring
Does anyone know the wiring colors for the door locks? I want to add a switch by the rear hatch that would allow me to lock the vehicle manually before closing the hatch. I use my HHR for deliveries and would like to be able to hit the lock button, close the hatch and walk away without having to juggle packages and dig out my remote. I figure it will be easy enough to tap into the lock wiring going to the hatch. Any idea if the harness is on the left or right?
Thanks,
CJ JAX
Thanks,
CJ JAX
Thanks for the help. Realized shortly after posting that the wires to the hatch lock would only be activation and not control. Still not too bad to run something to a switch in the back once I know what to tap into.
CJ JAX
CJ JAX
Cool idea. When the locks are activated with the hatch open, the door locks do lock, and when the hatch is closed it is locked as well, and the alarm system is activated (at least on my 06).
If you have a spare key fob you could mount it in the rear near the hatch - would save the trouble of running wires, mounting a switch etc..
I like the idea but you may want to do the extra key fob idea. the power locks are controled by the body computer. when you make a lock request at the switch a resistance value is set to the body controller then the controller activate the power lock motor or motrs depending on the programing. not as simple as taping on to the switch wires. you could tap onto the activation side of the wire but you would have to tap on to all of the power lock motors to get all the doors to lock.
Heres the diagram, looks like theres a white wire going from the BCM computer in the center console around and up into each door. Best way is to pick up another identical switch and wire it in, as it looks to use a straight ground to signal lock doors and a load resistor to signal unlock.
