Door Locks Will Not Lock
Old May 29, 2024 | 10:02 AM
Thanks for the follow up, keep it clean drive it often!
Old May 29, 2024 | 11:54 AM
greg8453's Avatar
Originally Posted by HDgary
Door lock issue resolved.
What I found when I was testing for voltages and continuity at the BCM connections was an apparent bad connection of one of the BCM connectors. I removed these to do my testing and after I reattached them the door locks would then lock as they should from the switch and from the fobs.
I appreciate everyone's help here. Thanks to all who provided input here.
Did you repair the loose connection? I hope it lasts.
Old May 29, 2024 | 01:20 PM
HDgary's Avatar
Not really sure what the root cause is or was. I am assuming just a bad connection at the contacting pin to connector. I had those connectors pulled off the BCM to do the test that you sent me a link to. All that checked good then I assumed it was the BCM going bad or at least the lock relay within the BCM. I put the connectors back onto the BCM and just for the heck of it I tried the door locks and they worked. After that while locking and unlocking I did jiggle the harnesses around and could not reproduce the issue. So hopefully it will last. If not then I will need to revisit the wiring and connectors for a better inspection.
LON
Mar 28, 2022 01:56 PM
Lee3333
Mar 24, 2022 09:33 PM
Nasaathoff
Jan 25, 2020 08:04 AM
Steve 1948
Sep 17, 2013 04:45 PM
JeffsHHR
May 23, 2008 08:20 PM
