Door won't unlock with key
Old Apr 24, 2019 | 04:16 AM
Jazz Cain Stargen's Avatar
No fob just a key
I'm at work locked out of my car with the only key in my hand.Need a jump but can't pop the hood.What in the world am I supposed to do?
Old Apr 24, 2019 | 05:47 AM
Cat Man HHR's Avatar
Use the key on the drivers door. Turn the key counterclockwise.
Old Apr 24, 2019 | 06:17 AM
If you're locked out and can't get in, how would you know that it needs a jump ???
Old Apr 24, 2019 | 08:23 PM
Good question, unless he tried "remote start" not available on all models.
Old Apr 24, 2019 | 08:44 PM
His post says "no fob, just a key" so I don't see him doing a remote start try.
Old Apr 24, 2019 | 09:01 PM
  #26
Nope, I missed that, no remote starting.
Old Nov 1, 2022 | 12:54 PM
  #27
Karhar's Avatar
Door lock does not work with Fob or Key
Originally Posted by ATLsilverSS
first off, my remote key fob does not lock/unlock my doors....hasn't worked in qutie some time. now i have been using the old fashion way of putting the key in the hole and turning. today i went to unlock my car after work and the key would not turn to unlock the door. it felt like something was stuck or lodged or something. i called a locksmith and he tried using a device though the door crack to grab ahold of the lock and pull it up. he got ahold of it but it would not pull up. again something was stuck or something. he was able to do this method on the passenger side door and i got in the car and for s&g i clicked the unlock button.......drivers door lock opened up with no problem.
i haven't fooled with it any since i didn't get home from work till about 3:30am because of this. i will roll the windows down tomorrow and fiddle with it and see what i can find out.
New message: I am having this exact same issue. How was this resolved? Was a repair involved? Thank you.
Old Nov 2, 2022 | 10:30 AM
  #28
We will never know the Original Poster never returned.
If you are not mechanically inclined you should call a locksmith. And get the fob working to avoid wear and tear on the locking mechanism.
Old Nov 2, 2022 | 02:24 PM
  #29
A low battery will cause the fob not to unlock the doors, use the ignition key in the door lock, if that doesn’t work or turn the lock it’s probably because the new ignition key wasn’t matched up to the vin when the ignition recall was done, if that’s the case then you need to call a locksmith.
Old Nov 3, 2022 | 04:11 PM
  #30
PulpFriction's Avatar
Sometimes funny things happen to the locks when a car is repo’ed.
