Door won't unlock with key
Old Feb 23, 2023 | 10:04 AM
  #31
Only1life's Avatar
U can not have another key or bottons in your car when it's locked.
Originally Posted by ATLsilverSS
first off, my remote key fob does not lock/unlock my doors....hasn't worked in qutie some time. now i have been using the old fashion way of putting the key in the hole and turning. today i went to unlock my car after work and the key would not turn to unlock the door. it felt like something was stuck or lodged or something. i called a locksmith and he tried using a device though the door crack to grab ahold of the lock and pull it up. he got ahold of it but it would not pull up. again something was stuck or something. he was able to do this method on the passenger side door and i got in the car and for s&g i clicked the unlock button.......drivers door lock opened up with no problem.
i haven't fooled with it any since i didn't get home from work till about 3:30am because of this. i will roll the windows down tomorrow and fiddle with it and see what i can find out.
if you have anything in your car that unlocks your door, your door will not unlock. Ok I tell you what happened to me. I put my purse in my car and locked my door, when I tried to unlock it it would not. So this happened once before. In my purse I have another key to my car. When the locksmith came car was unlocked, I took my purse out and locked the doors and the key in my hand worked. You can not have another key of car bottons in you car when locked ok. I took other key out and left it at home. It's never done it again.
Old Feb 24, 2023 | 09:58 AM
  #32
Hi Only1, to the forums!!
You need to get the door panel off and see what's really wrong, because your thoughts are just not correct. It's just a matter of time before you're locked out again. How do you think the car knows that you have moved your spare key a few feet away from where it was? The key has a transponder chip that the car's computer recognizes and allows the engine to start. That's it, the key doesn't communicate in any other way.
Old Feb 24, 2023 | 11:15 AM
  #33
Nether does the fob. Maybe you are not talking about a HHR. Maybe one of those "keyless start" cars, when you need to have some sort of key on your person in order to start the engine.
Old Feb 24, 2023 | 11:21 AM
  #34
Originally Posted by Only1life
””You can not have another key of car bottons in you car when locked ok. .””
what is a key of car bottons ? 🤔
Old Feb 24, 2023 | 11:34 AM
  #35
A fob with buttons on it
Old Nov 8, 2023 | 05:48 PM
  #36
RoaRanger's Avatar
Just wanted to thank youse guys - sittin' here waitin' for AAA. I vaguely remembered this as an HHR issue - hope they can get one of the other doors open.
What I remeber was a family almost dying when their HHR's battery suddenly died in the desert and NONE of the doors could be unlocked. a could passerbys finally stopped and broke a window - a couple of the kids were passed out by them :'-(
Old Nov 8, 2023 | 07:38 PM
  #37
I guess they were in too much of a panic to just pull the knob up? I wonder who makes these stories up?
Old Nov 8, 2023 | 09:08 PM
  #38
RoaRanger's Avatar
When their battery suddenly crapped out ALL of the electric door locks ended up in this half way jammed state. :O
Here's one account of it:
My bad, they did not get them out the broken window(s), they had to use the Jaws of Life :O
Old Nov 8, 2023 | 09:40 PM
  #39
Yes, the author even admits near the end that this is a fictional story. Some inaccuracies, the door lock knobs can be pulled up, even with a dead battery.
Old Nov 9, 2023 | 07:41 AM
  #40
The authors choice of an HHR was so wrong, should have gone with a PT Cruiser and least same manufacturer as Christine!
