Driver door
Old Oct 20, 2022 | 07:53 PM
HHRnovice's Avatar
Driver door
The driver's door on my 2009 LT makes a metal on metal sound when opened. It is starting to rust on the lower left corner of the door. I've checked and tightened the mounting bolts on the door but it hasn't helped. Has this been an issue with these cars? What might help to fix this?
Old Oct 20, 2022 | 09:49 PM
greg8453's Avatar
The vehicle has started to sag in the middle and the door isn't plumb with the post/pillar anymore and the door really needs to be aligned.
Old Oct 21, 2022 | 06:43 AM
Looking at the picture, the door gap to the fender gets wider as it goes higher. Take a look at the door hinges. The bushings and/or pin on hinge is probably bad.
Open the door. Lift up on the bottom of the back of the door. If there is any vertical movement or “looseness” then the hinge is bad.
If the hinges are good I would then look to see if the car has been hit in the front and pushed the fender back.
Old Oct 21, 2022 | 08:07 AM
The rust is a result of the poor fitment.
Old Oct 21, 2022 | 04:58 PM
Both the door and fender need to be adjusted for better gap fitment
Old Oct 21, 2022 | 08:20 PM
greg8453's Avatar
It's not sag as I thought or it would be closer at the top. Need an alignment done.
Old Oct 22, 2022 | 08:33 PM
HHRnovice's Avatar
The other doors are fine. If the car is sagging wouldn't other doors be misaligned too?
Old Oct 22, 2022 | 09:26 PM
greg8453's Avatar
I said it's NOT sag.
Old Oct 23, 2022 | 07:14 AM
no it’s not sag!
Old Oct 23, 2022 | 08:19 AM
You can adjust the fender. Loosen all the bolts then use a large screwdriver or other tool in the openings at the top to move it, then with your other 2 hands tighten the bolts.
