Driver door stuck
Old Apr 15, 2018 | 02:37 PM
Jcup Multhauf's Avatar
Driver door stuck
Hello I got one more problem that I need help with. Is it possible to take the driver side door panel off with the door closed? The door won't open from the inside or outside and can lock and unlock.
Old Apr 15, 2018 | 03:32 PM
It might be possible. The driver seat comes out by removing 2 bolts in the back the tilting forward on a catch.
Old Apr 16, 2018 | 02:43 AM
geg's Avatar
geg
I think it's possible.
The problem is that the door trim is blocked by dashboard and the elements of the doorway. Namely - trim of the central pillar. This trim is fixed by clips. If you remove it, you will have access to the clamp with a pressure element. If you manage to unlock it, further actions will be simple. Just tear off the door trim and access the door lock.
Even if you can not remove the door trim completely, you at least widen the hole and, possibly, you can unlock the lock
You will need something like a hook of steel wire to unlock "pressure element". Open the passenger door and you will see its location.
On the Internet there is video ... how to replace the inner door handle. The process of dismantling the door trim is well illustrated
Sydnika
2.2L Performance Tech
Jan 3, 2017 10:01 PM
KeithinPHX
Apr 20, 2016 12:43 PM
2smokey
Mar 11, 2013 08:01 AM
Leonard
May 29, 2012 10:34 AM
JT's HHR
Jun 29, 2007 03:59 PM
