Driver side window not working
The driver side window stop working. I replaced the regulator with a new one. But when I applied power to the old one it worked!! I bought a new switch assembly with a new one. (I think it was new) It did not cure my problem. I checked and there is no power going to the motor. I check all fuses pertaining to the power windows. All windows work except the drivers side.
WHAT AM I MISSING ?? |
The embarrassing question is what about the lock out?
The lock out is working !
Which window, front or rear?
The wire must have a break in it, both wires come directly from the switch. The driver switch has some sort of logic built in for the "one touch toll" feature.
The conduit plugs into the door, could be failure point. |
I'am not getting power to the up/down switch. How does the voltage get to the switch ? All windows work except the drivers side !!
I have replaced the window switch with two NEW ones and the drivers side window still will not work. I hear a clicking but there is no window movement. Could it be the EXPRESS LOCK ? Is this not part of the window switch?? If not where is this EXPRESS LOCK ?
This is on a 2010 HHR !
If you hear clicking either the motor is bad or you didn't install the regulator right.
The wiring is pretty simple, no scary computers involved. Dare I say: take the door panel off and observe? Here is the 2010 circuit; the other 2 windows are typical of the left rear shown. https://cimg7.ibsrv.net/gimg/www.che...43043278bb.png |
