Drivers side turn signal / brake light
Hey gang. I have an issue. Drivers side tail light works but not the brake light / turn signal. I have LED's installed but with a tester I'm getting no power to the socket. I've heard of broken wires. So my question is where do I start tracking the issue and what route is suggested. This issue came to light
after I first installed the load resisters and wiggling the harness "fixed" it back then.
Thanx for the help
after I first installed the load resisters and wiggling the harness "fixed" it back then.Thanx for the help
After untaping the wire bundle and looking inside it appears the yellow wire goes up. I see 2 yellow wires. Is this correct or does the yellow wire loop around and go down.
In the mean time I'm doing the front brakes, stabilizer bar bushings and links
According to the schematics, there is only 1 yellow wire. The right side has it's own grn wire. There is no connection between the stop/turn lights and the CHMSL. The lights are not fused except via the BCM.
