DRL not activating
Old May 26, 2021 | 07:00 AM
Allen P's Avatar
DRL not activating
Hey, so I was checking through the manual and I found this part where it said that the when the turn switch is in the auto position, then the drl is automatically activated with a 20 second delay when the light sensor detects light.
This doesn't happen in my car. The dashboard stays dim and the taillights, side marker stay lit until I switch them off after each ignition. I thought this was how the car was made... until now.
I'm pretty sure nothing is covering the light sensor, where do I start looking?
Old May 26, 2021 | 07:08 AM
I’d leave it alone, it is very possible that when your HHR was imported to your country, the laws were different for the lights and so the way they work was changed. Like in Europe, some countries mandate amber turn signals in the rear tail lights.
Old May 26, 2021 | 07:19 AM
"I'm pretty sure nothing is covering the light sensor "
Huh ? The light sensor is on the top, center of the dash, next to the windshield. You would know if it's covered or not.
If you have one of those add-on carpet dash pads, they can interfere with the light sensor working. I had to enlarge the hole in the carpet on mine for the sensor to work correctly.
Old May 26, 2021 | 08:16 AM
2006 works differently. the front turn signals are used; they don't come on unless the shifter is in drive.
scoutmstr
Maintenance and Upkeep
Nov 20, 2012 10:08 AM
SlickRick2
May 12, 2012 06:01 PM
Sasksurfer
Apr 24, 2010 11:12 AM
Marzipan
Feb 24, 2008 11:35 PM
fastsuv
Oct 2, 2006 07:25 AM
