Ecotec oil filters observation part II
Old Jul 25, 2007 | 06:41 PM
nfboy's Avatar
Originally Posted by Black Rose
The OEM filter is one of the filters that is being questioned as to whether there is an oil restriction issue.
See this is just nuts. Do people really think they know more than the company that built the vehicle? Why even ask the question? Why would the manufacturer use a filter on their vehicles that restricts oil flow. They are not completely clueless.
Old Jul 25, 2007 | 09:24 PM
Lone Ranger's Avatar
I'm not nuts, well not yet anyway The bottom on the Delco (Hengst) and Wix designs appears to partially cover the oil port. The bottom on the Supertech, Fram, Purolator does not. Does it matter? Probably not. But the design difference is there.
Old Jul 26, 2007 | 12:10 PM
Goose's Avatar
on the flip side though you get much more exposed media with the OEM vs the Fram or ST (on the inside)
As you said who knows if it makes a diff
Goose
Old Jul 26, 2007 | 12:16 PM
Black Rose's Avatar
It would be cool if we could get a clear cap for the cartridge canister so we could see the filter in action.
Old Jul 26, 2007 | 12:27 PM
Cool
I would buy one for sure. Not sure if a lexan type transparent could meet the specs for the filter cap though (heat range, torque tolerance of threads, plus overall strength).
Old Jul 26, 2007 | 12:34 PM
  #26
tsaints1115's Avatar
It would only work until you fired the engine and the flow of oil covered the lid obscuring the view.
Old Jul 26, 2007 | 12:43 PM
  #27
Doh! I should have realized that.
Old Jul 26, 2007 | 01:43 PM
  #28
dbfruth's Avatar
Why wouldn't it work? Unless you are poring black tar back into your engine when you change the oil. Granted it wouldn't stay clean enough to watch for very long because of the detergents in the oil but it should stay clear long enough to see what is going on.
Old Jul 26, 2007 | 07:33 PM
  #29
It wouldn`t work the same way heavy rain obscures your view while driving and thats a clear fluid. But hey,prove me wrong. No biggie.
Old Jul 26, 2007 | 08:25 PM
  #30
I had the filter compartment open tonight and I think I have the flow routing figured out anyhow. I believe the u-shaped port on the compartment floor to be the exit port. The entry port is at about the ten o'clock position (roughly) about an inch or so (again, roughly) from the top edge of the compartment. It is much larger. If my camera wasn't broken I'd have taken a photo.
