Electrical Issue Brake Lights/Rear Wiper/Cruise/ plate light
The cruise control will not work if the THIRD brake light does not work.
The third brake light is on a different circuit than the other brake lights.
You understand that the tail lights are not on when the DRL are on? I.E. on "auto" in daylight.
All of the rear lights are in the same bulb.
I will send you a couple of pdf files of the wiring via PM.
also if car is turned off and brake is pushed in... the License light turns on.
plovell66
Aug 4, 2016 07:07 PM
ZonedAgain
May 23, 2011 05:28 PM
