Electrical Issues , 2008 Lt
Old Oct 9, 2008 | 04:45 PM
DEVERAUXX's Avatar
Hello,
My car got hit by a truck on the passeger side 3 weeks ago, tearing down the front cover and fog lights. At first, the garage guy told me it will b a matter of changing the cover and that would be it, however, i ran into the following issues after they "fixed" my car:
1: The engine seems to tremble a lot
2: There's s strange noise coming from the engine
3: There's no light inside the cabibn, except for the stereo and the tacometer, gas level and speedometer.
4: Also, there's no light in the shifter, "the light from above" , steering wheel and the light from behind, they only work when i press the break pedal or i press the "emergency lights"
5: I cannot dim the lights, the button doesn't work
I did not have any of these issues with my car before the crash, and the engine is almosgt new ( 4,000 miles)
They checked the fuse box and told me it was ok, any ideas what may be causing this malfunction??? I would certainly appreciate some advise.
Thanks!
Old Oct 9, 2008 | 06:07 PM
ChevyMgr's Avatar
From what you state, it seems you have lost the ground for your lighting. I believe there is a ground strap on the front cover brace. The engine noise will need more explanation.
bigtimegearhead
Dec 22, 2013 04:44 AM
gwr
Jul 30, 2013 07:59 PM
Dvail
Aug 28, 2011 03:56 PM
PhoS
Nov 16, 2009 06:26 PM
HHR_Issues
Sep 19, 2008 02:03 PM
