Electrical issues.
I appreciate all the help. The only issue I have now is, traction control light comes on and service ESC before I even pull it out of park. 🤔
I am thinking it's probably wiring somewhere, or a bad or intermittent wheel sensor. Going to do some serious searching.
Wheel sensor problems are C codes. My scanner won't read them. High-capability scan tool required. I went to a parts store.
C0035 Left Front Wheel Speed Sensor Circuit
C0040 Right Front Wheel Speed Sensor Circuit
C0045 Left Rear Wheel Speed Sensor Circuit
C0050 Right Rear Wheel Speed Sensor Circuit
all pretty common. Might just mean the wiring is bad. There are other possibilities.
I appreciate the code information. I checked out the wiring a couple of times so be sure. It all seems to look pretty good. I also replaced the back wheel bearings with sensors, but not the front. It might be one of them. I'll run down to the parts store here in a little bit and see if they can tell me anything. I appreciate everything.
Those C codes are for ABS, your ABS light should be on if applicable. A bad wheel speed sensor or wire would turn the ABS light on.
ESC + Traction usually stems from a performance code, like one of the VVT codes or a transient VVT code that does not set the CEL. That is why I suggested the checks in #26.
