Electrical issues.
Old Jun 29, 2024 | 02:11 PM
  #31
Melvin G.M.'s Avatar
Ok I'll check that
Old Jun 30, 2024 | 08:10 AM
  #32
PulpFriction's Avatar
Originally Posted by donbrew
Those C codes are for ABS, your ABS light should be on if applicable. A bad wheel speed sensor or wire would turn the ABS light on.
ESC + Traction usually stems from a performance code, like one of the VVT codes or a transient VVT code that does not set the CEL. That is why I suggested the checks in #26.
I had an ESC light on and the only code was C0035. ESC can't work properly with a malfunctioning wheel speed sensor.
OOPS! Wrong. That was an ABS light. But I still doubt that ESC will be happy with a wheel speed sensor problem.
Old Jun 30, 2024 | 08:29 AM
  #33
ESC + Traction. Not just ESC. or ESC + ABS If the engine is not running properly there is no need for traction control, since it should be parked.
And "usually". Nice that you had an exception.
Old Jun 30, 2024 | 09:25 AM
  #34
I had a C0035 code in the spring, it was a defective brand new hub, the internal wires were broken!
Old Jul 15, 2024 | 02:35 PM
  #35
I was wrong. I had ABS light and C0035. Off to correct.
Old Jul 15, 2024 | 03:24 PM
  #36
Probably a hub gone bad on the left front
Old Jul 15, 2024 | 03:42 PM
  #37
Had a broke clip on a VVT plug. Went ahead and replaced both pigtails for VVT solenoid and problem fixed. No lights on dash except for TPMS. Can't fix that, it's the module. That is, unless someone out there has a suggestion.
Old Jul 15, 2024 | 04:35 PM
  #38
Since it is a 2008 the RCDLR module probably needs updated firmware. The 2008s had a problem with losing memory when the battery goes dead or removed. This condition probably started right after a new battery installation. Else, the batteries in the wheels only last about 10 years.
Somebody with a subscription to TechLine and a computer interface can fix the firmware.
scubanut
27
Jul 9, 2024 09:51 PM
Rocket Dawg
Maintenance and Upkeep
18
Apr 26, 2022 03:07 PM
janoka
Oct 30, 2021 09:43 PM
Eric Overmiller
Mar 22, 2018 10:07 PM
DukeofWagner
Jun 18, 2008 08:47 PM
