Electrical/Transmission/Dash/Power Steering Issues
Old 09-19-2008, 08:58 AM
Harpozep's Avatar
Originally Posted by ChevyMgr
You may have an electrical center (fuse box) issue, trying slapping the side of it or moving it around and see if the conditions change. Or you may have an ignition switch problem.
I opened the fuse box in the engine compartment and checked to see if all the fuses were seated. Looked at the wiring harnesses as well. Battery seems fully charged. started it again with no problem.
Called Chevy and have an appointment for Monday.
I hate intermittent problems. When something breaks, I want it to sty broke! You know what I mean? Then it can be addressed properly.
Harpozep is offline
Old 09-19-2008, 09:14 AM
ChevyMgr's Avatar
Normally the problem is a wiring connector problem underneath the electrical center or the electrical center it self.
ChevyMgr is offline
Old 09-19-2008, 12:16 PM
Harpozep's Avatar
Thanks. By electrical center you mean the fuse box in the engine compartment?
Harpozep is offline
Old 09-19-2008, 12:32 PM
ChevyMgr's Avatar
Yes.
ChevyMgr is offline
Old 09-19-2008, 02:03 PM
Harpozep's Avatar
Yes.
Thanks. Just reread you other post on it and saw (Fuse box ). My bad.
I'll see if I ca n do anything, but at least I can pass the info on to the Chevy techs.
Harpozep is offline
brazor06
12-11-2022 07:59 AM
HHRNewbie
01-12-2016 03:54 PM
greed
04-15-2014 12:41 AM
gwr
07-30-2013 07:59 PM
venomlegionsHHR
06-09-2012 06:52 PM
Quick Reply: Electrical/Transmission/Dash/Power Steering Issues
