Embarrassed newbie locked out! Help!
Old Dec 24, 2020 | 10:18 AM
In the US the kits were ordered by VIN, The keys and cylinder setup same as from the factory. So if the door cylinder is not the one from the factory the key won't work. The installer was supposed to confiscate the old keys, since the keyring hole was part of the recall.
As an bonus you probably have remote start after you get the fob programmed. If no button for it Panic + Lock does the same thing. After RS is activated in the DIC.
Old Dec 24, 2020 | 11:35 AM
OP reported that the key now works to unlock the door.
Old Dec 25, 2020 | 05:54 AM
my6thchevy's Avatar
Thanks & Merry Christmas! I did fail to add that I followed-up spraying a lubricant into the door cylinder after AAA left.
Old Dec 26, 2020 | 09:18 AM
geg's Avatar
geg
[QUOTE = Cat Man HHR; 905350] Я тоже разместил видео об использовании строки.
Возможно это то, что вы написали. [/ QUOTE]
Yes. Same.
In reality, I put the rope through the back door. This is more convenient because it is narrower and has a square window shape.
And the loop on my rope was not self-tightening. Just a loop because I don't know how to make tricky knots.
WoodysMobile
Sep 6, 2019 03:44 PM
Truckingeek
Dec 27, 2018 02:29 PM
DrTrapper
GM Recall Campaigns
23
Apr 10, 2014 12:27 AM
alexrckid
GM Recall Campaigns
Apr 9, 2014 09:21 PM
Batfink
May 6, 2007 02:15 PM
