Engine Air filter
Old Jun 10, 2007 | 01:30 PM
Goose's Avatar
How often are we supposed to check this dang thing? I know it says in the manual but here is a great opp for someone to add to their post count
Goose
Old Jun 10, 2007 | 02:52 PM
Lone Ranger's Avatar
The factory system appears to already be a cold air intake, as it appears to draw air from outside the engine compartment, i.e. the fore area of the passenger front fender inboard bulkhead serves to help isolate the end of the intake duct from hot under-hood air. How much heat the air takes on from heat-soak of the factory setup perched atop the engine is another matter. But technically it appears to source "cold" air from outside the engine bay.
Originally Posted by tireman1554
1. Disconnect the MAF sensor, PCV hose, and both ducts.
2. Pull the entire system from the top of the engine.
3. Throw that thing as far as you can!
4. Replace with friendlier, better looking, better performing cold air intake.
Old Jun 10, 2007 | 03:56 PM
hhrcrafty's Avatar
It's also designed to last for 50,000 miles, reduce underhood noise and vibration, and provide an efficient intake system for the engine. I've yet to see ONE aftermarket "cold air" (read: extremely HOT underhood air) intake that can match the OEM's performance in all three categories.
Besides, I've yet to see a quick-lube lackey bring my old filter in to show me how dirty it is and how I have to replace the perfectly good filter after only 1,000 miles.
Old Jun 10, 2007 | 04:14 PM
I avoid jiffy lube joints like the plague. I call them "iffy lube" because you never know if they did the job right. Plus, the filters they use can be really low end. If I'm not going to change my own oil, then I would use a reputable full service repair garage or a dealership service dept.
chevhhrdummy
Sep 30, 2014 07:48 PM
Robb
Jan 15, 2014 10:30 AM
menance
Dec 22, 2010 06:14 PM
