Engine Missing?
Old Nov 2, 2022 | 10:40 AM
Aj1968's Avatar
Engine Missing?
I have a 2007 with 2.2l, auto w/278k miles. I notice that as the temperature gets to the higher side over 200 the engine starts to pick up a (miss). The check engine light doesn't come on but there is definitely a different feel about how the engine is running. I have recently noticed also that the dash coolant temp gaugs sometimes climbs to 219 (once I saw 220 for a split second) could the sender unit for the fan be going bad? The fan does kick on but I am afraid for it to get too high and damage things. Any help is highly appreciated.
Old Nov 2, 2022 | 11:06 AM
Does the Check Engine Light come on momentarily when you start the car?
You can still check for pending codes.
Old Nov 2, 2022 | 12:05 PM
Have you checked the coolant level under the pressure cap and in the bottle? While moving the temp should stay 190-200F, in stop 'n go traffic it might get up to 220F the fan is supposed to come on around 217F.
The engine acts funny because "something is wrong". When the engine gets too hot the computer goes into "defense" mode, it will shut cylinders down in an attempt to cool down.
EnglishJimbob
Jan 5, 2022 05:47 AM
Toyoyoye
Jul 19, 2019 07:50 AM
sleeper
Sep 27, 2018 08:31 PM
alexrckid
Feb 22, 2012 12:35 AM
jbman
May 5, 2011 10:56 PM
