Engine Noise During Acceleration
Old Aug 31, 2011 | 04:01 PM
helhedded's Avatar
Air box hose could still be loose, regardless of if its standard operating procedure.
thanks for the reply
Originally Posted by nacademus
I feel like the dealership should have been able to find it in 5 minutes. Have you checked your oil level, just for the hell of it? Doubt it has anything to do with that.
It sound likes it could be an air leak. Have them re-secure it REGARDLESS of normal procedure on the prior work it received. Have you tried to pinpoint the sounds location yourself at all-as in popping the hood and giving it a listen?
Yes I have checked the oil level. Thanks for the tips, but I am not going to ask the Oil Change shop to re-secure something that they didn't touch. I'm sure that I could ask them to do it just to do it, but it wouldnt be because I thought that they screwed something up.
I have tried to pinpoint this problem underneath the hood and the only thing that I noticed was that I could feel air coming from somewhere. I know some motors can generate a fanning of air from the moving belts so It was hard for me to determine if that was normal or not.
Originally Posted by 843de
Another possibility once the airbox is checked for proper installation is a cracked down pipe leading from the exhaust manifold, if they break you will get a commotion close to what you's hear from a loose airbox.
thanks
A cracked downpipe/flexpipe would sound like a hiss and tick. Does it tick? You should also get a code.
no ticks and no codes
Flex pipe............ and you may or may not get a code, but you will get the noise.
I suppose a muffler shop might be able to tell me? I haven't been to one yet.
Old Aug 31, 2011 | 04:22 PM
You can see the flex pipe from the engine compartment, if it's cracked you will see black on it. (normally it's rust colored) You will also hear it really well if the engine is running and someone blips the throttle while you are looking at it....... Just don't get burned.
Old Aug 31, 2011 | 04:39 PM
helhedded's Avatar
Thank you for the tips. I plan on getting under the hood when I get out of work today. I'll post up afterwards.
Old Aug 31, 2011 | 07:17 PM
helhedded's Avatar
I checked the airbox (and changed the filter while I was at it) to make sure that it was secure. My neighbor came over to give it a listen (he's a certified mechanic) and his words were, " Wow that's going to be a tough one!" lol. He sat in an out of my vehicle while I was making the sound happen and he was stumped. I have to drive to Little Rock for a flight next week and if this is an exhaust leak I hope for it to at least be more noticeable after that.
Here is a pic of the flex pipe. It looks ok to me.
Old Aug 31, 2011 | 08:44 PM
It does look fine from the pic.....
Old Aug 31, 2011 | 09:34 PM
LawDog88's Avatar
Did you check the filler neck, make sure its securely fastened?
Old Sep 1, 2011 | 09:56 AM
helhedded's Avatar
Yes it is fastened.
Old Sep 1, 2011 | 10:18 AM
panelmoxie's Avatar
does your HHR eat a lot of Mexican food. That will always make my make strange noises
Old Sep 1, 2011 | 10:59 AM
helhedded's Avatar
No- lately it has been on a Mediterranean kick.
Old Sep 1, 2011 | 12:02 PM
nacademus's Avatar
I blame the green sway bar. Green is unlucky.
