Engine per reduced, code p0121, p2135
Old Jan 20, 2015 | 01:08 PM
britishknigth's Avatar
Solman 98 did your hhr went to engine Pwr Reduced state?
What was the symptom on that code for you?
Thank you
Old Jan 20, 2015 | 01:24 PM
Soloman98 did your Hhr went to Engine Pwr Reduced? Mine go in that state every time the check engine light appear.
What was the symptom on yours with the code 121? Did you get the 2135 code too?
Old Jan 25, 2015 | 05:11 PM
kornellred's Avatar
P0121 is the probable culprit. My own 2007 HHR LS 2.2 got several "engine power reduced" warnings back when it was new. There was a mismatch between the voltages produced by the throttle position sensor and the sensor in the accelerator pedal. It was caused by a bad connection (a loose or broken pin) inside one of the major plugs in the wiring harness. The dealer located the defective connection and fixed it. My HHR has not thrown a single code in the past 7 years.
Old Jan 31, 2015 | 02:33 AM
Kornellred thanks. It was the same description in mine.
Finally I fixed the problem. I use a lot my HHR on freeway for traveling and abuse use of the cruise control. Too much acceleration and deacceleration. So the potentiometer used to regulate the throttle opening, has a internal malfunction at some point. I changed the TB AND THE CODES vanished after 4 minutes running w/the new throttle body. I took me like 20 minutes to complete the process.
Thanks everybody 👍
Old Jan 31, 2015 | 04:22 PM
Glad it's repaired, enjoy that HHR!
Old Jan 31, 2015 | 07:28 PM
Cleaning the throttle body as suggested twice already, may resolve your problem.
chevhhrdummy
Sep 30, 2014 07:48 PM
Johnhern777
Apr 21, 2014 05:26 PM
ScoHHR2007
Feb 25, 2014 11:46 AM
pdmorris1
Feb 24, 2014 07:45 PM
ssjerry
Nov 27, 2013 04:29 PM
