Engine Performance
Old Oct 3, 2015 | 01:47 AM
dmartin_03's Avatar
Engine Performance
Hello all,
I have a 2008 HHR Lt. Recently, When i go to accelerate, It seems like the engine isn't giving me full power. It is weird because I haven't thrown a SINGLE code. Anyone have any idea whats going on? Thanks In Advance!!!
Old Oct 3, 2015 | 02:10 AM
Gonna need some more info.
How many miles on your HHR?
Manual or Automatic?
Any recent work done under the hood, like an air filter change?
Is it a hesitation, or does the engine "lay down" like it's not hitting on every cylinder?
Have you checked your fluid levels, oil and coolant?
The more info, the better.
Old Oct 3, 2015 | 02:12 AM
dmartin_03's Avatar
Sorry,
70,000 miles
Automatic
Nothing done under the hood.
It's kind of a hesitation. I step on the pedal, It doesn't give me the power then it sort of Wakes up per say and gives me the power.
Oil and coolant are okay.
Old Oct 3, 2015 | 02:21 AM
Off the top of my head, where all the gray hair resides, my first two thoughts are.
1. A dirty MAF Sensor.
2. A dirty Throttle Body.
Both can give your HHR a lag off the line, you can clean both yourself, but great care and the proper cleaning chemicals are needed.
MAF Sensors need "MAF Sensor Cleaner", and Throttle Bodies need "Throttle Body Cleaner" available at your local auto parts store.
If you Search for MAF Sensor cleaning and Throttle Body cleaning, you'll find threads on both topics on the site. But keep in mind, both parts can be easily ruined if you're not 100% certain of what you're doing. The Sensors aren't that expensive, but the Throttle Body isn't cheap.
Old Oct 3, 2015 | 02:23 AM
dmartin_03's Avatar
Thank you so much sir. I will try this when I get off.
Old Oct 3, 2015 | 02:54 AM
dmartin_03's Avatar
Sorry to bother you... I could not find a thread on cleaning the maf or where it is even located... I am sorry
Old Oct 3, 2015 | 07:54 AM
DrLoch's Avatar
Here is one link
https://www.chevyhhr.net/forums/how-...careful-51786/
Old Oct 3, 2015 | 09:42 AM
And here's another, it'll show you the location of the MAF Sensor and how to correctly remove the airbox assembly, and if your engine air filter hasn't been serviced lately...it's a good time to replace it too.
https://www.chevyhhr.net/forums/main...-filter-10757/
Sorry for the delayed reply, and many thsnks DrLoch for helping a fellow Member.
menance
Dec 22, 2010 06:14 PM
beachbum1970
Mar 25, 2009 08:46 PM
jmarines
Feb 17, 2009 11:43 PM
TurboTechRacing
Jan 14, 2009 06:48 PM
Don Juan
2.2L Performance Tech
10
Mar 13, 2008 06:28 AM
