Engine Power Reduced Light on
Old Jan 10, 2015 | 08:06 PM
  #31
hhr06NJ's Avatar
Originally Posted by hhr06NJ
this just happened to me tonite (Jan. 10, 2015) . Car stalled, would not start.
I dont remember now if i had a click or not when turning the key;
Sat for 5 minutes contemplating a tow truck, and then it started; "Reduced Power" message went away but Check engine Lite is on.
9pm
Bought a scanner at Harbor Freight.
Will scan tomorrow.
checked gas cap, then loosened and tightened
drove a few miles CEL went off.
Old Jan 11, 2015 | 02:51 PM
  #32
hhr06NJ's Avatar
9pm
Will scan tomorrow.
Dead thread.
I think I found the problem in archives
Old Jan 11, 2015 | 03:11 PM
  #33
So what code did your HF scanner find?
Old Jan 11, 2015 | 06:40 PM
  #34
Dead thread.
Wow. You revived this thread with your posted problem. Then said you would check back with the codes.
So, we waited to help out and the above is your answer ?
Not the way to be on a forum.
Old Jan 13, 2015 | 07:13 PM
  #35
hhr06NJ's Avatar
sorry, i didn't think anyone was listening, or didn't see the post since it was an old post. thought i was talking to myself.
anyway. didn't check codes until today (wet and bitter weather for a few days-didn't realize how easy it would be to hookup) however-no codes
has run ok since.
perused dozens of topics in archives.
not many real solutions. lots of attempts.
sent an email to another member-she found water from a clogged sunroof drain caused wet wires somewhere-after 4 dealers and 4 independents. i dont have a sunroof, and was dry weather for me.
other opinions:
connector in left kickpanel-loose or wet.
connector pin at throttle body
wires rubbing-chafing under hood-a TSB somewhere
fusebox connection
oil reminder not reset for awhile (i think this was my problem)
bad battery
thanks for the followup.
i will keep looking-checking
Old Jan 18, 2015 | 11:09 AM
  #36
Drcrazytrain's Avatar
I ran into the same problem, after weeks of looking for the problem I found a small piece of paper towel on th MAF sensor. I thought no way that could be the problem. I cleaned it before putting it back in. Cleared the code, it started right up, took it for a test drive and it ran like a cat with turpentine rubbed on its butt.
Old Jan 19, 2015 | 10:11 AM
  #37
Meow that burns!!!!
desmonda
Dec 24, 2014 07:43 AM
rocco11189
2.0L Performance Tech
18
Aug 5, 2014 10:47 AM
Johnhern777
Apr 21, 2014 05:26 PM
T-Rodius
May 19, 2013 09:50 PM
menance
Dec 22, 2010 06:14 PM
