engine stalls when cold
Old Feb 20, 2018 | 06:01 PM
Close, the fuel pump delivers 30 GPH at 44 PSI
https://www.rockauto.com/en/catalog/...assembly,10147
Old Feb 20, 2018 | 06:15 PM
boatops's Avatar
Thanks Oldblue
Old May 18, 2018 | 11:43 AM
db2006's Avatar
Originally Posted by donbrew
Not a return line it is vapor from the tank. The HHR fuel system is pressure regulated so it does not use a fuel return line.
But could be pinholes in the fuel line.
BTW: for the folks that think there is a design flaw that makes the lines inherently susceptible to corrosion.
Aluminum is even more susceptible to corrosion from the outside and the inside from alcohol in the fuel.
http://www.diva-portal.org/smash/get...FULLTEXT01.pdf
Old May 18, 2018 | 01:16 PM
perhaps that is why it is galvanized?
yrral
Nov 4, 2013 04:47 AM
Jimmy~O
Oct 8, 2013 02:39 PM
tkfross
Aug 6, 2010 08:51 PM
OhioPest
Aug 24, 2009 12:48 PM
avanbaggett
Feb 19, 2009 02:56 PM
