Engine won't start, starter don't engage.
Old Sep 22, 2022 | 06:53 AM
Garyroe75's Avatar
Bought this 2011 with problem. Had a GPS tracker but was tracker only, Enterprise Rental. If key is not right will it try to start or not ? Thanks in advance.
Old Sep 22, 2022 | 06:57 AM
greg8453's Avatar
You bought it like this?
Does it crank? Lights?
Old Sep 22, 2022 | 06:59 AM
I moved this to it’s own thread, wasn’t relevant to thread from 2008.
depending on the tracker device and how it was removed, it shouldn’t render the car to not start.
check the fuse box for loose relays and fuses, are the 7 mm bolts tight?
Garyroe75's Avatar
Yes,
I replaced ign switch. Starter works jumping relay.
Old Sep 22, 2022 | 07:00 AM
Check your work at the ignition switch, any wires loose? Ground wires?
KenK
Mar 13, 2022 08:10 PM
bchappelow
Jan 31, 2019 11:16 PM
Paquinr89
Jul 6, 2016 04:47 PM
Sundance
Sep 6, 2015 08:48 PM
ChevyMan1992
Apr 16, 2015 03:26 PM
