Some Sort of Electrical Issue (Need Help)
Old Sep 21, 2022 | 06:27 PM
MunKy_x's Avatar
I am having some sort of electrical problem with my 2008 HHR LT. When I connect my battery I only get some lights on my radio to come on and everything else is dead (picture below):
[SOLVED] - I needed to tighten the bolts in the fuse box until tightened completely (after the popping sounds)
This problem started when I went to replace some solenoids in my transmission. To do that, I had to take out the fuse box and both the ECM and the TCM. I did disconnect the battery before I took everything apart. Here is a list of the things I replaced in the transmission:
  • Manifold pressure switch
  • Lockup and trim solenoid
  • 2 Shift solenoids
  • Automatic transmission pressure control solenoid valve
After I got everything together I got an error code: P1682 (ignition switch)
  • I replaced the ignition switch and changed out the relay and it still didn't work.
I reconnected everything and checked everything and ended up getting P0443 (Evaporative Emission Control System Purge Control Valve Circuit) and U0101 (Network) codes
I had a power steering and reduced engine power warnings on my dash. So I decided to go through and clean up all the grounds; I sanded the connectors and sprayed them with CRC electrical contact cleaner. I also sprayed the contact cleaner into the neutral safety switch and the computer connectors.
Now, when I reconnected everything I get the picture above. I twice went through the fuses and fuse box and checked all the relays with my ohms meter and couldn't find anything wrong. I do get power up to the fuse box. I had the battery tested and it is good and has around 81% charge. What could the problem be? I would like to at least get power back to my lights and locks and everything if I have the dealership diagnose it. Thanks.
Also, unrelated, can anyone identify the broken hose by my battery in the picture below?
eng pwr reduced
Old Sep 21, 2022 | 08:51 PM
Broken hose by the battery is the vent tube for the battery.
Old Sep 21, 2022 | 09:08 PM
On the side of the underhood fuse block, under the red cover should be 2 large wires. The lug closer to the firewall should have 1 smaller red wire for the power steering.
Old Sep 21, 2022 | 09:30 PM
The bolts that hold the fuse box together need to be tightened a lot more than you think. That is typical in cases where the fuse box is removed. 4 this month.
You need to tighten them until you hear a "crack!!!", that is when the fuse pins connect.
Old Sep 21, 2022 | 10:03 PM
MunKy_x's Avatar
You are talking about the 5 7mm bolts that are in with the fuses? I have tried tightening them, but it seems like they are stripped basically. I have tried to tighten them to a reasonable amount. The all the clipped around the fuse box are clipped in place. I may go out and check here in a few. I'm afraid of stripping them more.
Old Sep 21, 2022 | 10:06 PM
MunKy_x's Avatar
I definitely have those 3 wires connected very tight.
Old Sep 21, 2022 | 11:52 PM
MunKy_x's Avatar
That fixed it. They actually do tighten up. Although, 1 click isn't enough -- the one clicked like 2-3 times. Thanks a lot.
Old Sep 22, 2022 | 07:03 AM
Resolved! Awesome!
Rap808
Mar 15, 2022 12:13 PM
uluz2a6
May 2, 2020 08:57 AM
professor229
Jan 9, 2020 06:17 PM
129k2006
Feb 23, 2016 06:01 PM
rad white panel
Aug 1, 2010 08:09 PM
