No power and key in stuck switch
Old Aug 1, 2010 | 04:50 PM
rad white panel's Avatar
I am getting my car ready to pull behind the motor home. Owners manual states to pull fuse # 8 on inside fuse block. I read on the internet to put a switch on the fuse #8 so it does not have to be pulled every time. I made up a simple switch and installed it tried it out and now I have no power to anything! I removed the switch and installed the fuse back into the block but have no power any where and cant take key out. I have checked all fuses and they are ok and there is no power ( interior lights,door lock, windows) but there is power at the front battery connection. What did I do wrong?
Old Aug 1, 2010 | 05:00 PM
In checking the fuses did you also re-seat them? I've read they can become loose over time and with you working in the area maybe one became dislodged....... just a thought.
Old Aug 1, 2010 | 06:26 PM
I have checked all fuses and even disconnected the battery for 20 min. still nothing. Well guess Ill call the dealer and have it towed to get it fixed. It figures I just worked some overtime last week and there it goes.
Old Aug 1, 2010 | 08:09 PM
an08HHR's Avatar
Did you check the fuse that is back by the battery? That 50 amper sends power to other circuits such as those your interior lights are on. There is a another direct cable that goes to the front of the car and you would have power at that point, which you say you do. I would look at that big fuse by the spare tire and if it is blown, you sure did short something.
gharrison42
Jul 2, 2019 11:45 PM
NappiiRoots
Aug 10, 2018 04:17 PM
Kookie
Jan 24, 2016 10:40 PM
Robert Jennings
Feb 13, 2015 07:28 PM
dlmhhr
May 31, 2012 02:55 PM
