Power window stuck open
Old Feb 8, 2015 | 04:31 PM
Robert Jennings's Avatar
Hi I lowered my front passenger power window and it wouldn't go back up. all others work so it isn't the fuse. Opened up the panel and was able to pull a cable out that looks like it went to the upper rear part of the window mechanism. I can see there are four of them that go to each corner of the window. The cable has a knurled end that fits into something but I can't see it or get my fingers into the area to see where it came out off. Is it possible that it just came apart or is it just broken and in need of replacement? can I remove more parts so that I can get my hands in there? The motor whirls as though it's working ok and I can't see any broken pieces laying inside the door anywhere. Should I just take this to a real mechanic? Am I over my head. I'm not a mechanic by trade.
Thanks,
Robert
Old Feb 8, 2015 | 05:07 PM
I haven't worked on the HHR mechanism myself, but did you try a Google search ?
I did and it does shows a few pictures.
https://www.google.com/search?q=hhr+...AUoAw#imgdii=_
Old Feb 9, 2015 | 02:48 AM
Lucky's Avatar
In most cases when the cable comes out of place it's because a plastic guide somewhere has broke allowing the cable to jump out of its track.
The motor then twists up the cable in nots. I would recommend replacing the complete window lift assembly.
Old Feb 9, 2015 | 04:40 AM
Ok great thanks. After looking inside it looks pretty hopeless. Going to have to replace the whole mess. I didn't pull the regulator lift assembly out yet but I watched a video online and it looks pretty easy. Now I need to find a good price for one. May have to just tape the window up until I can order one. Tomorrow's agenda.
Old Feb 9, 2015 | 06:20 AM
NAPA carries many window regulators and lifts. Also try eBay.
Old Feb 13, 2015 | 04:59 PM
Part came today. Was a simple matter of replacing the power window regulator lift assembly. Really simple bolt on part. Cost was $86.97 total. I was worried I'd have to pay someone a lot more than that to do it for me. I wish all our problems could have as simple a fix as this one.
Old Feb 13, 2015 | 07:28 PM
Glad it is fixed and you get to feel the pride of doing it yourself, contrary to popular believe these little truck lets are easy to work on for the most part!
NappiiRoots
Aug 10, 2018 04:17 PM
bobalouhill
Apr 25, 2017 08:11 AM
P0757
Drivetrain (Excluding Engine)
Jan 23, 2015 07:39 AM
mikes40
Jul 27, 2012 03:29 PM
rad white panel
Aug 1, 2010 08:09 PM
