Auto shift button will not depress
Old Feb 12, 2015 | 09:11 PM
artfx1's Avatar
2008 HHR LT auto. Some mornings when I start the car the shift button will not depress. After a few minutes it will. I hear the clicking under the dash when the brake pedal is pressed, but the button on the shifter will not depress to change gears.Ive seen issues here where the button will not release out, but not this.
Thanks
Old Feb 13, 2015 | 05:59 AM
I typed "shifter stuck in park" into the search box and found this.
https://www.chevyhhr.net/forums/how-...ark-fix-52951/
Old Feb 13, 2015 | 06:51 AM
I have a letter from GM about this PM customer service with your vin!!
Old Feb 13, 2015 | 08:50 AM
Key stuck in ignition is a separate but related issue.
Old Feb 13, 2015 | 09:16 AM
Plus it could be a case of the shifter mechanism needing lubrication, an '08 is old enough, and Tenn is hot enough in the Summer/cold enough in the Winter to cause a shifter to "hang up". as the factory lube dries out.
Old Feb 13, 2015 | 11:03 AM
artfx1's Avatar
How do I PM GM customer service?
Old Feb 13, 2015 | 11:48 AM
db/sb's Avatar
https://www.chevyhhr.net/forums/priv...=newpm&u=24127
Old Feb 13, 2015 | 11:52 AM
Don my letter is for the shifter sticking
Old Feb 13, 2015 | 05:18 PM
The one I got today on the 2008 that lives in a salvage yard somewhere is for "key stuck".
My 2011 had the "shifter stuck" problem, I solved it with WD40, as in the posted video.
But either way, both fixes are posted in the "how-to" forum and are both simple.
Old Feb 13, 2015 | 07:33 PM
They are I gave mine at shot of Jig A loo and lubed it up been working fine
DeliaM83
Feb 2, 2014 10:16 AM
majic1984
Jan 23, 2014 07:06 AM
paperboy72
Mods - Interior
0
Oct 23, 2013 11:15 AM
irod87
Oct 15, 2011 11:39 AM
mchuntley
Mar 29, 2008 12:36 PM
