Sometimes power window won't open
Old Jul 26, 2012 | 07:53 PM
mikes40's Avatar
I've had my 2010 HHR for almost a year. Started about two months ago. Sometimes when you get in the car, shut the door and start the car, the power window will not open. When you open the door (while still running), it opens, you close the door, then is ok for the rest of the trip. Does this intermittently. I don't remember it doing it when the car is off, the door is shut and the key on, but not running. I will have to try that. Any ideas?
Thanks
Old Jul 26, 2012 | 08:11 PM
Snoopy's Avatar
You have a strange happenstance much like a couple of friends.
One has a Ford the other a Mercury and each have essentially the same problem you are describing. If they hit the door, rather hard, sightly in front of and below the armrest, the window switch will work. You might want to try that.
I would suggest, if this works, there is a lose wire connection.
Old Jul 26, 2012 | 08:29 PM
Bingo! Snoopy pegged it Mike. You've got a bad connection in the door, or an internal fault with the window switch itself.
Old Jul 26, 2012 | 08:47 PM
Warranty?
Old Jul 27, 2012 | 02:38 PM
Depending on how many miles are on the vehicle, this should be something covered under the Bumper to Bumper limited warranty.
Old Jul 27, 2012 | 03:29 PM
Joepoppa1's Avatar
mine does it if I happen to have the button pushed when I start the car... I wait about 10 seconds and it works fine after that.
bobalouhill
Apr 25, 2017 08:11 AM
Robert Jennings
Feb 13, 2015 07:28 PM
meveritt
Jan 29, 2013 09:13 AM
jpmcnam58
Oct 31, 2011 08:15 PM
flamin-gitaur
Sep 12, 2007 12:35 AM
