View Poll Results: ESC. Active
Steering fuse for ESC
66.67%
Disabling ESC
33.33%
ESC fixes
0
0%
Anything ESC
33.33%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Esc
Old Sep 1, 2022 | 05:23 AM
Verner's Avatar
Esc
I know I have to pull the fuse to disable ESC and one member said it's in the engine fuse box under steering. 60 Amp fuse. Is this correct? There's also a steering fuse in the inside fuse box. Which one do I pull? I'm not trying to fix it, I just want it disabled.
Old Sep 1, 2022 | 06:40 AM
What’s up with your Electric Steering?
Old Sep 1, 2022 | 07:36 AM
fst100's Avatar
slightly off topic, but is the 60 amp fuse the OP mentioned the one to pull when doing a dyno pull?
Old Sep 1, 2022 | 07:45 AM
Why is this a poll ?
Some strange choices in that poll.
Old Sep 1, 2022 | 07:50 AM
Why not push the button on the dash to disable the ESC?
Why is this a poll?
Is there a reason you want to destroy the car?
Have you looked at the fuse label on the box or in the Owner Manual (see link in my sig)?
Is your actual question "what do I do about the Service ESC message"?
Old Sep 1, 2022 | 10:17 AM
greg8453's Avatar
Where do you guys come up with these senseless polls? It's a poll that has no possible value as it is without any sense at all.
WHY THIS POLL?
Old Sep 1, 2022 | 10:21 AM
"We" didn't make it a poll, the OP did.
I guess the OP thought that was the same as adding search terms.
I will try to edit the thread.
Tried couldn't. Maybe Oldblue can.
Old Sep 1, 2022 | 12:05 PM
greg8453's Avatar
I wasn't pointing a finger at anyone except the OP.
I doubt he will answer me but I'm curious to hear from one who's brain works like this.
Why?
Old Sep 1, 2022 | 12:52 PM
Verner's Avatar
do brew tech advisor
Well duh! I did all that and that's exactly why I asked to disable it!!!! When it goes to ESC active is much worse on the car than what happens when I disable it. In addition thank you grammar patrol! You were zero help. I just need the number of the fuse that's it!!!!!!
Old Sep 1, 2022 | 12:59 PM
Verner's Avatar
Greg8453 senior member.
Exactly what should I have done? Please enlighten me!!!! Some of you are zero help. I'm not a guy, thanks for assuming! I'm new to the HHR and am learning as I go. Perhaps if some of you experts were more helpful people coul actually learn something!!!!!! I want the number of the fuse, that's it. If you won't help then don't reply.
