View Poll Results: ESC. Active
Steering fuse for ESC
66.67%
Disabling ESC
33.33%
ESC fixes
0
0%
Anything ESC
33.33%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Esc
Duh. Pushing the button on the dash turns it OFF. The only time it should be activated is when wheels are moving at different speed or the car is sliding in a direction other that where t6he steering wheel is pointed.
You can start a new thread by clicking on the NEW THREAD button. Then put a subject in the header then explain your question.
There are 2 fuses on the under hood fuse box labelled "ABS", the ESC is controlled by the AB computer.
Fuse #1 is the EPS fuse.
If you really want help you should not be so thin skinned. Forgive us for asking for more information, so that we could try to help you. Goodbye.
Exactly what should I have done? Please enlighten me!!!! Some of you are zero help. I'm not a guy, thanks for assuming! I'm new to the HHR and am learning as I go. Perhaps if some of you experts were more helpful people coul actually learn something!!!!!! I want the number of the fuse, that's it. If you won't help then don't reply.
