View Poll Results: ESC. Active
Steering fuse for ESC
66.67%
Disabling ESC
33.33%
ESC fixes
0
0%
Anything ESC
33.33%
Multiple Choice Poll. Voters: 3. You may not vote on this poll
Esc
Old Sep 1, 2022 | 01:14 PM
I doubt that someone will help you disable a safety system without knowing why.
You could start with what symptoms you're experiencing.
Old Sep 1, 2022 | 02:49 PM
greg8453's Avatar
Originally Posted by Verner
I know I have to pull the fuse to disable ESC and one member said it's in the engine fuse box under steering. 60 Amp fuse. Is this correct? There's also a steering fuse in the inside fuse box. Which one do I pull? I'm not trying to fix it, I just want it disabled.
Do you normally take a poll when you have a question? Your poll is for what purpose?
Old Sep 1, 2022 | 04:39 PM
Duh. Pushing the button on the dash turns it OFF. The only time it should be activated is when wheels are moving at different speed or the car is sliding in a direction other that where t6he steering wheel is pointed.
You can start a new thread by clicking on the NEW THREAD button. Then put a subject in the header then explain your question.
There are 2 fuses on the under hood fuse box labelled "ABS", the ESC is controlled by the AB computer.
Fuse #1 is the EPS fuse.
If you really want help you should not be so thin skinned. Forgive us for asking for more information, so that we could try to help you. Goodbye.
Old Sep 1, 2022 | 06:11 PM
greg8453's Avatar
Exactly what should I have done? Please enlighten me!!!! Some of you are zero help. I'm not a guy, thanks for assuming! I'm new to the HHR and am learning as I go. Perhaps if some of you experts were more helpful people coul actually learn something!!!!!! I want the number of the fuse, that's it. If you won't help then don't reply.
The question is fine and I believe your answer is above. I just can not understand what the poll is for or about. I guess I'll never know.
Old Sep 1, 2022 | 07:14 PM
Here you are, both fuse boxes fuse and relay locations
captneuman
Jun 6, 2021 11:42 AM
zKabi
May 24, 2017 07:57 AM
esmarkey
19
Jul 7, 2011 12:19 PM
DukeofWagner
Jun 18, 2008 08:47 PM
c2vette
Jan 25, 2008 12:55 PM
